Flashster
Nov 15, 2017Follower
Powerline 1000 no internet
My power lines randomly stopped working . No clue why , I reset them several times and my router /modem . I unplugged everything and re connected everything . Still no internet . Appreciate any advice !
1 Reply
- clithesProdigy
I had this once and nearly pulled my hair out for two hours trying to reset every router / modem / powerline I owned. Turned out something happened with the electricity supply / fuse box that started causing interference. I flicked the main electric off and back on and all worked perfectly well again. If you've tried everything else may be worth a try?
Otherwise, all your reseting may mean the units are not sharing the same encryption key anymore. Try setting them manually by connecting them to a PC / laptop individually to make 100% sure they have the same key
Hope this helps
