sh1ff
Aug 11, 2016Tutor
Powerline 1000 PL 1010 causes slow network throughout the house
Hi All, I have 4 Powerline 1000 PL 1010 adapters installed around the house. 3 of them work very good and I get ~50Mbps up/down link (with Verizon Fios 50/50 link). The 4th one is causing serio...
JamesGL
Aug 17, 2016NETGEAR Employee Retired
Hi sh1ff,
Would it be possible if you could interchange the other working powerline adapter with the one that is not working? On the area where the working powerline is connected, replace it with the powerline that you mentioned having problems and use the working powerline on the are where you want that powerline to work. Check and observe the connection.
JamesGL
Community Team
- sh1ffAug 18, 2016Tutor
I've done it and results are the same.
Thanks.
