mslisaj
Jul 26, 2017Guide
Powerline 1000v2 adapter has third status light red sometimes
I am using a Nighthawk EX7000 extender and have this plugged into the PL1000. All is working perfectly all the time. Occasionally on the PL1000 I will note the third green LED will turn red and the...
michaelkenward
Jul 27, 2017Guru - Experienced User
That's probably the "Pick A Plug LED".
It is telling you that the data rate is changing. There may be some interference on the mains. If things are working as expected, don't worry.
What passes for a manual explains this:
mslisaj
Jul 27, 2017Guide
Thanks for taking your time to respond. I'm not very worried about it as all is working very well. But yes, the manual, the NETGEAR customer service does leave a whole lot to the imagination. Fabulous products practically nonexistent customer sevice or help.
Thanks for your time to respond.
Lisa
