adrianmessenger's avatar
Jun 19, 2017
Powerline 1200 -- Securing Network
Is there any way to verify the Powerline Network is secured?  There is no assigned status light for the encryption being enabled, nor a color or blinking code, so how do I know it has been enabled?
  • michaelkenward's avatar
    michaelkenward
    Jun 20, 2017
    In the desktop genie, did you right click the plugs?
    This gives more information and the ability to change the names.
    I'm no expert on this, but I reckon that your analysis is spot on.
