ZurekNC
Dec 27, 2016Aspirant
PowerLine 1200 + Ethernet Switch
I've installed 4 Powerline adapters per the manufacturers instructions. The system works great when I have the computer or TV connected directly to the PL1200. What I want to do is install an etherne...
clithes
Dec 31, 2016Prodigy
Are you saying entire connectivity is gone? You cannot even connect wirelessly directly with your modem/router?
- ZurekNCDec 31, 2016Aspirant
Yes, all connectivity, wired & wireless. Everything works fine for some amount of time (not sure how long) the no connectivity. Removing the switch and rebooting the router and things return to normal. Repeated several times to be sure.
