ZurekNC
Dec 27, 2016Aspirant
PowerLine 1200 + Ethernet Switch
I've installed 4 Powerline adapters per the manufacturers instructions. The system works great when I have the computer or TV connected directly to the PL1200. What I want to do is install an etherne...
simonali
Jan 11, 2017Aspirant
I'm having similar issues. I had a Netgear XAVB1004 feeding my TV, blu ray player, NowTV box and Sonos in a different room to where the router is located and it all worked just fine. Decided to upgrade because I wanted to feed another computer and TV upstairs an internet supply and the XB101 refused to speak to any AV200 adapters other than the 4 way one that came with it. I went and bought 2 packs of PL1200 adapters and a 5 port switch so that the 4 devices previously mentioned all had an internet feed, but half an hour into watching a streamed programme on any of them and it just stops. I've already wasted money buying the AV200 adapters for upstairs that wouldn't work and now I've spent another £120 on a load more kit that doesn't work properly.
ZurekNC
Nice to know I'm not alone. My current way of addressing it is to use 2 PL1200's, one for a PC with poor WiFi capability), a second for a TiVo Mini (must be hardwired). The 3rd unit I wanted to hook to the switch is a work PC that I bring home on weekends. That one runs fine on WiFi. In my case, it's problem addressed, not problem solved.
