ZurekNC
Dec 27, 2016Aspirant
PowerLine 1200 + Ethernet Switch
I've installed 4 Powerline adapters per the manufacturers instructions. The system works great when I have the computer or TV connected directly to the PL1200. What I want to do is install an etherne...
cliveu
Jan 11, 2017Tutor
Sumonali, the 4 port switch at your TV end is fine. It should work well. The most likely problem is interference on your mains. Perhaps a dodgy charger or power supply unit.
- simonaliJan 11, 2017Aspirant
Oops, that won't be easy to track down, there are dozens of power adapters and chargers dotted all around the house! Any idea why the AV200 stuff wasn't affected in the same way?
