VioD
Nov 07, 2016Aspirant
Powerline 1200 getting 10% speeds only 10 yards from modem
I have Frontier (Verizon) Fios 100/100mbps internet. I'm using an Actiontech MI424WR Rev I router. The WiFi from the router works great as long as I'm in the room it's installed in, but it's t...
- Nov 10, 2016
I actually exchanged it for another brand and it's working much better. Thanks for the reply.
michaelkenward
Nov 08, 2016Guru - Experienced User
VioD wrote:I purchased the Netgear Powerline 1200 in hopes that giving the Fire TV a direct ethernet connection would improve the speeds, but it seems to be even worse than the WiFi.With just the Master router connected and set to channel 11, I get around 90 mbps down/100 up via WiFi in the same room. When I run the test from the living room I get about 25 mbps down/55 mbps up.
It isn't easy to unravel this. Is the Fire TV using wifi or direct, wired, LAN with the Powerline?
Direct is best. If you get seriously slow speeds then investigate that. If it is a wifi link, then check that the plug and router are using different SSIDs so that the poor TV isn't getting confused about which one to connect to.
VioD wrote:Now when I run a speed test I'm only getting about 7 mbps down/ 20 up.
Again, confusing for me. 7 Mbps down should be good for TV. But if you get 7 Mbps down and 20 Mbps that is really odd. It suggests that the plugs are doing fine, or they would not get that seriously good upload speed.
VioD wrote:I then configured a router as an AP (gave same SSID as Master, assigned static IP, disabled DHCP, put on different channel 6).
You seem to have tried all sorts of quirky things that may do more harm than good. Start with a bog standard approach. No fancy tricks.
Then add refinements as needed.
But someone else may have a better understanding of what is going on. As I say, I am bit baffled. I just follow what goes by here and the system you have set up should do just fine. It isn't that dissimilar to what I use.
- VioDNov 08, 2016Aspirant
Sorry for the confusion.
Plugging the Fire TV directly into the Powerline adapter via ethernet gets 7 mbps down/ 20 up (I downloaded a speedtest via kodi addons).
Connecting the Fire TV via WiFi gets 25 mbps down/55 mbps up.
I hope this makes more sense.
- JamesGLNov 10, 2016NETGEAR Employee Retired
Hi VioD,
Speeds can vary depends on how far the distance are. This is same as the wireless. The farther the distance it travels(electric current) the slower the connection.
JamesGL
Community Team
- VioDNov 10, 2016Aspirant
