dancalv
Sep 09, 2015Follower
Powerline 1200 Ground Terminal
I will be traveling to Mexico next month and while there I was planning to use Powerline 1200 devices to extend Internet to other parts of the house. The problem I forsee is that I am pretty sure th...
JamesGL
Sep 11, 2015NETGEAR Employee Retired
Hi dancalv,
Welcome to Community!
It should still work of you plug the 3 prong powerlin adapter to a 2 prong adaptor. The purpose of the ground prong is to prevent the powerline from being damaged if there will be a short circuit. But before using it, check first the power specification of the device if it is applicable in the region that you will be using it, for example the voltage and the ampere.
JamesGL
Community Team
