Net-1253's avatar
Net-1253
Follower
Nov 07, 2018
Powerline 1200 issues PS4 and Netflix etc.
Hello
I have a Virgin Media setup with Superhub 3 as my wifi router. I also have the Virgin V6 box for TV.
When I had it installed Virgin suggested I get Powerline adaptors as the hub and V6 are in separate rooms. My wifi on mobile phones, laptop, Now Tv box etc is very good.
I bought 2 boxes i.e. 4 plugs. I have been using 3 of them for a while. (1 into the Superhub, 1 into the V6 box and 1 into a spare Virgin Tivo box in a 3rd room).
There are 2 main issues A) and B).
A)
I always have the three green lights displaying on all 3 adaptors, but I have a couple of problems with the V6 and Tivo box:
1) I watch Netflix through Virgin Media and maybe 2 times an hour the programme I am watching will freeze and I have to wait a few minutes for it to reconnect.
2) You can access the recordings (made on V6 box) onto the Tivo box in the other room. While watching a recording in this way it drops out every few minutes.
I did speak to Virgin about this a while ago,  but it continues and I have just put up with it till now.
B)
I have just set up my son's PS4 in his room and connected it to a 4th Powerline adaptor. Again all 3 lights are showing, but he is getting very slow download and upload speeds about 1MBPS.  When we were playing the PS4 previously in our lounge we got a really good connection and speeds were really good. This was from wifi only. (not from plugging the PS4 into a Powerline adaptor).
Please can you advise regarding both problems A) and B).
Many thanks
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Net-1253,
    Welcome to NETGEAR Community!
    Please factory reset the adapters by pressing the reset button. Can you also try to wired a computer to the adapter and check if you experience these issues?
    Blanca
    Community Team
