MichaeLionheart
Mar 14, 2018Follower
Powerline 1200 not working xbox one
Bought Powerline 1200 for my xbox one, have them both plugged in and connected, all green lights are on but it wont connect me to xbox live, keeps giving me the error message "Can't connect to your D...
michaelkenward
Mar 15, 2018Guru - Experienced User
You might like to look into connectivity issues for the XBox. You may find that it is not related to the Powerline device. What happens if you connect the Xbox to the router? Does that work?
- michaelkenwardMar 15, 2018Guru - Experienced User
