EricLevy
Apr 24, 2017Follower
Powerline 1200 Pick a Plug Light Color Fluctuation
Evening all: I purchased my Powerline 1200 Adapter about six weeks ago and the connectivity was fine - I was getting 75 Mbps, which is what I pay for with my Internet provider. Then, about two da...
michaelkenward
Apr 25, 2017Guru - Experienced User
You could try putting the plugs close together and seeing what happens. If the speed goes back up, then there isn't a problem with the plugs. It is more likely to be something local.
