EricLevy
Apr 24, 2017Follower
Powerline 1200 Pick a Plug Light Color Fluctuation
Evening all: I purchased my Powerline 1200 Adapter about six weeks ago and the connectivity was fine - I was getting 75 Mbps, which is what I pay for with my Internet provider. Then, about two da...
A_dAb
Aug 03, 2017Aspirant
Similar to at least one other poster this year, an installation that has been running satisfactorily for about a year has broken down, to the extent that speed at the end of the link is <1/10 of that at the start of the link, and the pick-a-plug indicators on either end are flip-flopping erratically between red and green, with no obvious pattern.
Re-siting the connectors is not an option, and besides, the set-up was fine before.
I did attempt a factory reset with the units temporarily side by side, but did not get the expected temporary flashing as they re-established their network, so wonderignif it worked at all.
is it possible/necessary to get firmware updates for these units?
michaelkenward
Aug 04, 2017Guru - Experienced User
