snicolay
Dec 20, 2016Aspirant
powerline 1200
I have 4 Powerline 1200 units that worked flawlessly for over a year. Not one issue. Just today, 2 of them have the ethernet lights not lighting. I tried reseting all of them, the router and modem bu...
snicolay
Dec 21, 2016Aspirant
Thank you for your response. I tried that this morning and I get the router
unit blinking, plug in one of the ones that do not work and get that one
blinking then they both stop blinking after a while but the ethernet light
never lights up the whole time. Just the power led and the bottom security
turn green. I have been testing them in the same room too.
clithes
Dec 23, 2016Prodigy
Do you have any devices connected and using the internet when you are testing them? (or at least switched on to obtain an IP address)
If not, you will only see the top and bottom lights lit.
Also, have you tried checking Genie to see whether it sees all units when plugged in and turned on?
