Rodney1505
Mar 11, 2023Aspirant
Powerline 2000 - All lights are green but no internet
I have a Powerline PLP2000 duo and recently added a 3rd node (PLP1000). All 3 lights are green on all 3 devices. 2 Powerlines are communicating well (1x PLP2000, 1x PLP1000) both have access to the...
michaelkenward
Mar 11, 2023Guru - Experienced User
Rodney1505 wrote:
The 3rd node (PLP2000) shows full connection (3 green lights) but has no internet connection. I have changed a number of data cables but still no internet.
Have you tried swapping the plugs around?
That would help to work out if it is a plug or socket issue.
Another test is to put the PLP2000 alongside the router. If t works there, then it should work elsewhere. If not, I'd suspect the mains wiring.
Rodney1505
Hi Michael
I have tried swapping around but not putting the PLP2000 in line. I will try that.
The thing is, it used to work before I added the 3rd node?!
