Rodney1505
Mar 11, 2023Aspirant
Powerline 2000 - All lights are green but no internet
I have a Powerline PLP2000 duo and recently added a 3rd node (PLP1000). All 3 lights are green on all 3 devices. 2 Powerlines are communicating well (1x PLP2000, 1x PLP1000) both have access to the...
Rodney1505
furthermore I am not sure why I have 3 green lights on all nodes?
michaelkenward
Mar 12, 2023Guru - Experienced User
All three LEDs on all plugs tells you that all plugs have the mains on (one LED), they are all communicating with each other at top speed (second LED) and there is something plugged into the LAN plug.
You said earlier:
"The 3rd node (PLP2000) shows full connection (3 green lights) but has no internet connection."
What says "no internet connection"? The plugs may be doing exactly what they arte designed to do, but the device connected to that plug is misbehaving. We cant tell what that might be without more information.
What is connected to that plug? And what happens when you try to use it?
