wfavero's avatar
wfavero
Tutor
Feb 19, 2022
Powerline 2000 will not perform
This post is just some general observations before I return my Powserline 2000 to BestBuy.
Using Speedtest.net for all speeds...
Connecting my computer directly to my modem ---                                                        930 Mbps
Connecting to modem via WiFi (eero 6 dual-band mesh Wi-Fi 6 router)  ---    285 Mbps
Connecting via the Powerline 2000        ---    130 Mbps
Connection via Powerline 2000 after doing factory reset                                 ---    119 Mbps
I know you can't really trust marketing information, but this thing doesn't even com eclose to anything advertised on the box or website.  Since it is only 2 days old, hopefuolly BestBuy will give us a full refund.
The point of this post....   Buyer beware......
  • they make a flat ethernet cable on monoprice that can be hidden pretty easily.
    I've used that before.
    Or even relocating the modem could be an option. Many houses are wired for coax
  • plemans's avatar
    the problem with powerline is how many different things can impact its speeds.
    If you're crossing circuits, those speeds are actually pretty good.
    I'd highly recommend reading a few tests/reviews on powerline devices
    Powerline - Ranking (smallnetbuilder.com)
    • wfavero's avatar
      wfavero
      Tutor
      Thanks for the advice...  However, I will be abandoning this particular solution, unfortunately.   I was looking to the Powerline units just as a convenient way to ethernet connect to my modem.  I'll will now just take the time to "hide" the ethernet cables and direct connect.
      • plemans's avatar
