mwith
Jan 29, 2019Follower
Powerline 500 And Multiple Devices
Hi, thinking of buying a Powerline 500 device. I need it for two separate bedrooms. Can I have multiple end points from one device on the "other end" where it is plugged into the router? I would need...
Blanca_O
Feb 03, 2019NETGEAR Employee Retired
Hi mwith
Welcome to NETGEAR Community!
Depending on the powerline model, you can connect up to 64 nodes. Kindly check tech specs of the device to make sure about the exact number.
Please check the following reference link:
Product FAQ: Powerline Adapters
Adding a powerline adapter to an existing powerline network
Blanca
Community Team
