EricaE
Oct 22, 2016Initiate
powerline 500 compatibility with other powerline 500s
I already have this installed and it's working for 2 computers (base computer plus one more). Now I want to add a third computer and I can't for the life of me figure out whether to buy another set o...
- Oct 23, 2016
EricaE wrote:...I can't for the life of me figure out whether to buy another set of this same model or a different model.
Your call.
AV 500 is an IEEE industry standard. You can mix and match different speeds and brands.
I have done this, but if you want to be able to use them with the same controlling software and "genies", it is easier to stick to the same brand.
One problem is that Netgear, and other makers, like to sell these things in pairs. So it isn't easy to buy a "singleton".
Be warned that a mixture of plugs will default to communicating with one another over the mains at the speed of the slowest plugs on the network. So, add AV 1000 plugs to AV 500 plugs and you will get AV 500 speeds.
michaelkenward
Oct 23, 2016Guru - Experienced User
Your call.
EricaE
Oct 23, 2016Initiate
Thank you Michael!
