MikeSmith69
Jan 21, 2016Aspirant
Powerline 500 xavb5421 Issues
I have just dug these powerlines out my drawer and have attempted to connect my sons PS4. As soon as I plug the powerline into my existing router it drops all other devices off the internet and then ...
clithes
Jan 25, 2016Prodigy
What router do you have and where exactly are you plugging these in ? It sounds like you may be plugging the powerline adapter into the WAN socket of your router, and not one of the (typically) 4 Lan sockets
If they are paired (in fact even if they are not) they shouldn't have any detrimental affect on the router by simply plugging them in
- MikeSmith69Jan 26, 2016Aspirant
It does not matter which socket I use. I am using the latest BT Home Hub and i`ve tried it in every LAN socket except the red socket for obvious reasons you have just mentioned.
- JamesGLJan 31, 2016NETGEAR Employee Retired
Hi MikeSmith69,
Please connect the 2nd adapter in same room with the 1st adapter where it is connected to the router. When resetting make sure it plugged in to the socket.
