jaj38
Dec 30, 2016Follower
Powerline 500 XWN5001
My network extender has been working for a couple of years no problem. It now frequently loses connection to the access point. If I switch it off and on it will reconnect but will drop out again after...
- Jan 22, 2017Find the IP address of your adapter by looking at 'Attached Devices' in your router settings. Alternatively connect to the wifi channel from the adapter and then go to www.mywifiext.net in a browser. Or use Netgear Genie Network Map, click on Powerline Adapters, and then right-click this adapter and select 'Configuration'. Now you will access the adapter's GUI (default username and password are 'admin' and 'password') Go to 'Advanced' then 'PLC Settings' and turn off power saving mode. I find this to be temperamental on most Netgear powerline adapters, including their newer models: Hope this helps
michaelkenward
Jan 06, 2017Guru - Experienced User
Is this a wireless connection?
Hard to know what is going on here. What are you connecting to what?
- OMATIC73Jan 06, 2017AspirantI am having issues wirelessly and direct connect. I have been trying to log into genie with the default password and the little icon just spins forever. - OMATIC73Jan 07, 2017AspirantBelow are two screenshots of the issue I am having. I am clearly connected. This happens through wifi and ethernet. Any help would be appreciated. - michaelkenwardJan 08, 2017Guru - Experienced UserIt is hard to read those screen grabs. If you use Alt+Print Screen it will capture only the top Window. You seem to be locked out of the Router Settings. Is that because it rejects the password? Remember, the router password is not the same as the wifi password. As to losing wifi connections, one recent visitor found that he had better success by tweaking the wifi settings, changing the band and other settings. Re: Netgear D6400-100UKS - 2.4GHz Network Issue - NETGEAR Communities He also saw interference from nearby wifi networks. The symptoms he saw were identical to those described here, the wifi worked fine for a bit and then fell over.
