ttudora's avatar
ttudora
Powerline 500 XWN5001
Since Genie is no longer an app supported by Netgear and my Router, the Deco 6e, doesn’t have a WPS button, how can I bind the Powerline 500 to it using a Mac? It's a new router (to me) and a new Wifi setup.
  • michaelkenward's avatar
    michaelkenward
    ttudora wrote:
    Since Genie is no longer an app supported by Netgear ....
    Which genie?
    The desktop genie software for Windows and Macs is still there and is one way to work with Powerline networks.
    Netgear is trying to kill this useful utility, but for the time being you can find it here:
    genie | Product | Support | NETGEAR
    Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress.
    Download
    Once installed, Powerline shows up as its own network in the Network Map.
    Just another user with time on their hands.
    • ttudora's avatar
      ttudora
      Thank you SO MUCH for this! I found it difficult to find on their website. Very grateful!
        michaelkenward
        Another tip, there are other brands of Powerline. They seem to have the same technology. Many of them still have support software that also works with Netgear's devices, especially when you want something to disable "sleep" mode.
