Atjbat
Oct 17, 2015Aspirant
Powerline 500
I ask of istituzioni possible to do a bridge between wireless and 2 connector lan. Bye
Atjbat
Oct 23, 2015Aspirant
I have a dongle wifi in my room ,I want to connect it with powerline master and in my garage I have a powerline "slave" where I connect my laptop wired
thank you
bye
thank you
bye
JamesGL
Oct 23, 2015NETGEAR Employee Retired
Is your WiFi dongle a USB type? The powerline adapter needs to be connected to a router via an ethernet cable in order for to provide connection to the other powerline adapter.
JamesGL
Community Team
- AtjbatOct 27, 2015Aspirant
No this is a dongle wifi vodafone without wired la connector
Therefore my purpose is impossible
- JamesGLOct 28, 2015NETGEAR Employee Retired
The setup that you want will not work with the device. It needs to have a router with wired connection for the powerline to work.
JamesGL
Community Team- AtjbatNov 04, 2015Aspirant
I haven't found solution but my friend suggest me a router:
netgear wn2000rpt
He tell me that this router extender can convert a wifi signal to wired lan,
It's right?
