daviddesh
Oct 16, 2016Aspirant
powerline adapter to my router so I can move it
how to connect a powerline adapter to my router so I can move it to a better location in my home
michaelkenward
Oct 17, 2016Guru - Experienced User
Move what? Router? Plug?
You can put the router where you like but the plug has to be connected to it.
Then you can put other things on the second (or third or more) powerline adapter.
- daviddeshOct 17, 2016Aspirant
then the second of these connections is the modem, right? Because now the modem and router are in different rooms.
- michaelkenwardOct 17, 2016Guru - Experienced User
You didn't mention a modem.
Perhaps you can explain what you want to do.
cable modem is in one room and I want to move the router to another room. can't change the modem location it's a fixed cable entery point.
add a powerline adapter to modem in one room and add the powerline adapter to the router in another room. the powerline adaplter is pluged into the router where the modem normally plugs in directly. This I believe would create the connect to the router and the modem. Then add other powerline adaplters in order to connect more devices to the router.
Its the physical connnections to the router and modem I need help with in order to make this idea work if at all possible.
