SuperNet12
Jul 11, 2020Follower
powerline adapter
Hey there! I'm currently having a strange problem that's suddenly occurred: My powerline adapter will either drop dramatically in signal or will just disconnect entirely. I've had this setup for at l...
Jul 12, 2020Guru - Experienced User
Certain devices can add inteference into the power line.
If you've already narrowed it to activites on one device, then you've actual done the largest part of the work. It could be that device's power supply is going bad, having issues, or even something else in it is causing issues.
