DL7's avatar
DL7
Powerline adaptor doesn't allow network connection
Netgear Powerline adaptor XAV5401 no longer allows network connection for TV or DVD player - devices receive invalid IP address (? from Netgear) and gateway can't be seen. Setting fixed IP addresses ...
  • clithes's avatar
    Apr 19, 2016
    Yep possibly.  I would factory reset the unit to see if this resolves the issue first
