TUN11's avatar
TUN11
Follower
Apr 07, 2020
Powerline adaptors and security
Hi I bought 2 powerline adaptors and they worked fine so I bought 2 more (this time with plug passthru). I read you can have up to 8 set up in the house. Only 2 are connected I have tried pressing the button for 2 second per instructions (first the main unit that is plugged into the router) and then the new adaptors but they were not connecting.  I have now seen post about setting them up in same room before moving and that has worked thankyou.  Should i be doing something to make them secure?  Thanks
  • plemans's avatar
    syncing them does sync the security key. That's how you're making them secure.
  • michaelkenward's avatar
    michaelkenward
    Remember, when adding new plugs to an existing network, you need to follow this advice:
    >>> Adding a powerline adapter to an existing powerline network <<<
    You need only one plug connected to the router.
    Beware that advice. People have complained here that they hit a brick wall when they connect a sixth plug to the network. I'm not sure if this applies to all plugs, including the PLP1000.
