nazdom's avatar
nazdom
Follower
Jul 08, 2017
Powerline Adpters
I wanted to network two computers and a TV to the router.  Looking at the adapters I came across the PowerLINE WiFi 1000 WiFi Powerline Kit.  I thought that would be good for the TV because I also have an Amazon Firestick and as it is wifi only it can struggle.  However I do not need wifi with the computers so which standard adapter will communicate best with the WiFi Powerline base adapter?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    I'm not sure that I follow what is going on here. What do you wanty to connect to what?
    You can buy powerline adaptors with or without wifi.
    If you don't need the plug to deliver wifi, get the ones without it.
    How are you trying to connect the TV to the network? Wifi or LAN? If the TV has LAN, that would be best.
