Tom129
Mar 28, 2017Aspirant
Powerline and range extender
At the moment I use a tp-link wifi range extender and connect it to my pc using an ethernet cable. It is terrible, my ping whilst playing games is terrible. I was told a powerline would be better. Wha...
- Mar 29, 2017
I still don't understand why the PL1000 is cheaper and why you say amazon doesn't sell XAVB5101, it does in the UK.From the page you point to, Amazon does not sell the XAVB5101 in the UK. The link you gave shows that the item is "Dispatched from and sold by NETWORK LTD." That is not Amazon.
Anyone can use the Amazon front end to sell things. That is why this device is "Not eligible for Amazon Prime."
Why is the XAVB5101 more expensive? Because there are suckers out there willing to pay over the odds? Other suppliers sell the same plugs in the UK for £26.85 plus shipping. That seems like a more reasonable price for out-dated stock that sellers want to get rid of.
They may even have supplies of the XAVB5101 at your nearest branch of Currys. Look in the"bargain bin".
Currys prices there are likely to be better than Amazon. At Currys the PL1000 is £24.97, the same as Amazon.
michaelkenward
Mar 28, 2017Guru - Experienced User
Tom129 wrote:
What is the difference between a powerline and a range extender?
A range extender is wifi. Powerline is wired over your mains circuit.
And is the XAVB5101 a good one?
It is the previous generation. Bit slower than today's models, but probably fast enough for most needs.
Product FAQ: Powerline Adapters | Answer | NETGEAR Support
Powerline Networking | Powerline Ethernet | NETGEAR
