Rober1n
Jan 11, 2016Aspirant
Powerline AV 500 no longer working
I have a Powerline AV500 with two plugs which although not used often has worked reliably since I purchased it. It he connection has now stopped working, one plug has no lights on. I have factory res...
Rober1n
Jan 19, 2016Aspirant
Hi, when I try this the lights on the second Powerline light up when the power is first switched on then after a few seconds all go out.
JamesGL
Jan 20, 2016NETGEAR Employee Retired
Hi Robert1n,
If same thing happens with when connected in just one room then the router might be defective. Check if it has reset button. If yes, reset the powerline adapters. If same thing happens, replace the adapters.
