Dez
Mar 10, 2017Follower
Powerline AV200
Hi, I have the powerline AV 200 and one plug in adapter, I need to add another plug in adapter to the system, This product is no longer available. Can I use the Nano instead and will it work with...
- Mar 10, 2017
Yes.
These discussions may be useful:
PLP1200 powerline PLUS PLW1000 or 1010? - NETGEAR Communities
Solved: Powerline AV + 200 (XAV2501) compatability - NETGEAR Communities
There are plenty more like that in the forum.
michaelkenward
Mar 10, 2017Guru - Experienced User
Yes.
