AAJ102a
Nov 28, 2017Aspirant
Powerline ethernet 85 Mbps turbo works, 200 Mbps doesn't, will 500+ work?
Strange problem with powerline ethernet (bear with me, I know results are highly variable). I originally bought a pair of 85 Mbps (Turbo) powerline ethernet adapters to hook up my AV gear to the ...
michaelkenward
Nov 29, 2017Guru - Experienced User
Did you "factory reset" the plugs?
You are trying to revive seriously old devices. The technology has come on apace since AV200. The older ones won't even adhere to the AV standard.
AAJ102a
Nov 29, 2017Aspirant
Yes, I tried factory reset.
The original Homeplug AV standard is much older than these units, although that has little to do with it. You can still buy new 200 Mbps units in the store, so it's a current standard. More to the point, the old Turbo 85 Mbps mode (not a HomePlug AV standard) uses up to 30 MHz, just like the later 200 MHz Homeplug AV standard.
The newer Homeplug AV2 standard is more recent, and uses frequencies up to 85 MHz.
- michaelkenwardNov 29, 2017Guru - Experienced User
Netgear specifically states that its original Powerline devices use Home Plug 1.0 Specifications, which will not work with newer plugs.
The people behind the technology say that "HomePlug AV uses frequencies in the range of two to 28 MHz. The IEEE 1901 standard extends this range optionally to 50 Mhz. HomePlug AV2 utilizes frequencies in the range of 30 to 86 MHz to increase throughput."
It is the Ethernet speed that matters.
I'm sure that people are still trying to unload 200 Mbps plugs, although most suppliers abandoned them some years ago, as 500 Mbps and then 1000 Mbps devices arrived. The price of 1000 Mbps devices has come down to levels that make it silly to contemplate buying 200 Mbps plugs, if you can find some. But the choice is yours.
Fortunately, 200 Mbps plugs are AV compliant and will work with 500 and 1000 plugs, albeit at the speed of the slower devices.
