JimmyW's avatar
JimmyW
Luminary
Dec 17, 2017
Powerline for newbie
I now use a WNDR4300v2 router with my Samsung UN65KS TV.  I've had several network connection issues, like dropped connections to the Internet.  In another thread, someone suggested Poweline, about w...
  • michaelkenward's avatar
    Dec 18, 2017
    JimmyW wrote:
    Is it as simple as plugging in one unit and attaching it by ethernet to my TV, and plugging in the other unit and connecting it by ethernet to my router?
    That's about it. Do it the other way round.
    Plug unit into router, sonnect LAN and then plug LAN from TV into other unit.
    JimmyW wrote:
    I take it that the TV would find the network seamlessly, though with my wireless setup, I have to choose the network and login to it with my password.
    You won't need a password to set up the LAN link, but you will have to faff around with the TV to tell it which network to use, wired rather than wireless.
    The Samsung UN65kKS8000 does not show up in Google, so it is hard to be definitive about setting it up. But past experience and messages here show that "smart" TVs are actually very dumb, and can take a bit of fiddling around with. But you know that already from the wifi set up.
    The PLW1000 would work, but it is actually more powerful than you need for a TV. I use "500s". The PLW1000 has a LAN socket that does 1000 Mbps. That is fine for modern PCs but most TVs work as 100 Mbps.
    Did you realise that the PLW1000 has a "remote" plug, the one for the TV, that also acts as a wireless access point? Do you need wifi for something else in the room? The TV won't use it, so you can get away with the cheaper PL1000.
