bkorin
Sep 23, 2015Aspirant
Powerline Model: XAVB5201 pick a plug LED is green then turns red when streaming.
As mentioned in subject line. All the LEDs are green, but as soon as I begin streaming video the pick your plug LED turns red. When I exit the streaming video program it goes back to green. Model: XA...
JamesGL
Sep 25, 2015NETGEAR Employee Retired
Hi bkorin,
Welcome to Community!
How far is the 2nd powerline from the first powerline? Can you try to connect it in same room with the 1st powerline and try streaming.
JamesGL
Community Team
bkorin
Sep 25, 2015Aspirant
The two rooms share a wall. I will try a different outlet and get back to you.
- bkorinSep 26, 2015Aspirant
Tried multiple outlets. Still get the red light when streaming. Oncre the stream stops or I exit the stream app the light goes green.
- JamesGLSep 28, 2015NETGEAR Employee Retired
When you do normal use of internet like browsing websites, does the light turns amber? I think the reason for that because the powerline cannot handle the data when streaming.Regads,
JamesGL
Community Team
- bkorinSep 29, 2015Aspirant
When browsing the internet the LED stays green. Only when I stream video does it turn red. Do I have a way of adressing this issue?
