smcrook's avatar
smcrook
Powerline PL1200 and PLP1200 on same network
I recently bought a pair of PLP1200 adapters and was very happy with how they performed so I bought an additional two PL1200 to cover the rest of the house. I'm having trouble getting all four powerl...
  • michaelkenward's avatar
    michaelkenward
    Sep 11, 2017
    Correct. The "client" for the modem network cannot act as the host for the second network. You'd have to create a second powerline network.
    As I said, you could get round the wifi issue by using dual-purpose powerline plugs that come with a wifi repeater.
    One scenario that I haven't tried is to add a separate wifi repeater on the powerline ethernet network and then to use the repeater's LAN ports to join the network. That would avoid losing the plug's LAN port.
