1di9
May 25, 2018Tutor
Powerline PLP1200 disconnections
I'm using a couple of PLP1200 Powerline for over a year now and it's been some time I've noticed that, during a day, they disconnet from network several time, letting my Pc without internet or LAN c...
nonsaprei
Jun 08, 2018Aspirant
I have the same problem. I really hope there's actually a way to solve it and that it's not related to the house's wiring, because I'm probably not gonna move anytime soon, and even if I did, the probability of going somewhere with modern wiring isn't high...
P.S. My product is brand new, though. It's been having this problem since the very first day.
P.P.S. I've searched a bit and I found a couple of people saying it can be caused by overheating. My powerline isn't very hot though, but it does have a power strip plugged into the extra outlet. I'll try to plug that into another outlet and also monitor the heat.
- 1di9Jun 09, 2018Tutor
According to me is not an issue house wiring related.....Taking a look around forum, I read about many people complaining about this identical defect.
Overheating? May be.....Then it could be a design error, it must be taken into account that the temperature of this device is subject to increases due to the electric load if it is equipped with a passing outlet.
I'm considering replacing it with something more reliable, like the powerline of the AVM....I use Fritz!box 7490 as router and access point.
- nonsapreiJun 09, 2018Aspirant
I've plugged the power strip into another outlet but the problem still arises even when the device isn't hot... It happened twice in not even 2 hours. I have to just stop using it and go back to wifi...
- 1di9Jun 16, 2018Tutor
I replaced these powerline with Fritz! Powerline 1220E, I was fed up with the continuous connection leaks.
In these few days of use I did not have any similar problem.
