jbander1
Jul 04, 2018Aspirant
powerline plw1010
The second light from the left comes on tan but goes on and off. and I cant connect with my tablet. Ever though it shows the netword and the signal is excelent.
michaelkenward
Jul 17, 2018Guru - Experienced User
That is the Pick A Plug LED.
Is the PLW 1010 delivering a wired network?
There is support and a manual for the PLW1010 somewhere at the end of this link:
>>>> PLW1010 | Product | Support | NETGEAR <<<<
- jbander1Jul 17, 2018Aspirant
I have the manual that came with it. If there is something different that you were sending me to then , I get "no such page" I have to think that my wired system won't let wifi go through my wiring sucessfuly for some reason. Which kind of makes my purchase quite a waste of money.
- michaelkenwardJul 17, 2018Guru - Experienced User
Looks like they moved it.
Try this:
jbander1 wrote:
I have to think that my wired system won't let wifi go through my wiring successfully for some reason.
I have no idea what that means. The wired system does not "let wifi go through" it.
It lets the two plugs work as wired LAN devices. Then the remote plug connects to the router's plug and has a wifi access point that spits out its own wifi signal.
The wifi bit will not work if the wired bit fails. So sort that out first and then set up the wifi.
I'm afraid I don't understand your first message. YOu say:
For a start, what does "comes on tan" mean? Amber?
If I am right and that is the pick-a-plug light the colour will indicate the quality of the connection over the mains. Look at the manual to work out what is going on. Amber is OK but not great. Green is best.
I assume that you are trying to connect your tablet with wifi.
Set the plugs up in the same room, then move the wifi one to where you want it. The plug will remember its settings.
Don't give up. These things are notoriously difficult to set up.
Well first I think we are talking about two different things a powerline runs the wifi through your electrical system. We have to start at that point.
