jbander1
Jul 04, 2018Aspirant
powerline plw1010
The second light from the left comes on tan but goes on and off. and I cant connect with my tablet. Ever though it shows the netword and the signal is excelent.
jbander1
Jul 17, 2018Aspirant
I have the manual that came with it. If there is something different that you were sending me to then , I get "no such page" I have to think that my wired system won't let wifi go through my wiring sucessfuly for some reason. Which kind of makes my purchase quite a waste of money.
michaelkenward
Jul 17, 2018Guru - Experienced User
Looks like they moved it.
Try this:
PLW1010 | Product | Support | NETGEAR
jbander1 wrote:
I have to think that my wired system won't let wifi go through my wiring successfully for some reason.
I have no idea what that means. The wired system does not "let wifi go through" it.
It lets the two plugs work as wired LAN devices. Then the remote plug connects to the router's plug and has a wifi access point that spits out its own wifi signal.
The wifi bit will not work if the wired bit fails. So sort that out first and then set up the wifi.
I'm afraid I don't understand your first message. YOu say:
For a start, what does "comes on tan" mean? Amber?
If I am right and that is the pick-a-plug light the colour will indicate the quality of the connection over the mains. Look at the manual to work out what is going on. Amber is OK but not great. Green is best.
I assume that you are trying to connect your tablet with wifi.
Set the plugs up in the same room, then move the wifi one to where you want it. The plug will remember its settings.
Don't give up. These things are notoriously difficult to set up.
- jbander1Jul 17, 2018Aspirant
Well first I think we are talking about two different things a powerline runs the wifi through your electrical system. We have to start at that point.
- michaelkenwardJul 18, 2018Guru - Experienced User
No it doesn't.
Did you read what I wrote?
Powerline runs the ethernet through the mains. (You can get powerline systems that do not support wifi.)
The ethernet connects the two plugs. In the PLW1010 and other powerline wifi systems the "remote" W plug is also an access point.
You can even use Powerline to run strandard wifi access points. I currently have a powerline network that has an Orbi router at the "remote" end.
We have to start understanding how these things work. You will not get wifi to work over powerline until you get wired LAN to work over powerline.
I have explained how to do that. If you cannot manage that process, then you would do better to return your plugs and buy something that is simpler to set up.
- jbander1Jul 18, 2018Aspirant
You might want to think about its name "powerline" I really don't know how we can go anywhere with this because it's the house wiring that seems to be the problem.
One way to connect a network-capable home theater component to your router is by using powerline adapters. A powerline adapter is an alternative to running in-wall Ethernet cables or relying on possible unstable WiFi. A powerline adapter has the ability to send your music, photo, video, and computer data over your household's existing electrical wiring just like it would over Ethernet cables.
A network-enabled home theater component or other network device connects to a powerline adapter using an ethernet cable. The powerline adapter is plugged into a wall electrical outlet. Once plugged in, you can use the powerline adapter to send and/or receive media files and data over your home's electrical to a second powerline adapter plugged in another location. To do this a second powerline adapter is plugged into a wall electrical outlet near the location of your router. It is connected to your router using an Ethernet cable.
