BillSyratt
Oct 26, 2019Initiate
powerline utility for Mac
Hi, I have had no problem using Netgear Powerline Utility 3.1.0.3. on my iMac using High Sierra. The issue will come when I replace my computer and start using Catalina. It will only accept 64 bit a...
michaelkenward
Oct 28, 2019Guru - Experienced User
Netgear has not produced a Powerline utility in years. Probably because you don't need one.
What do you want on to do with the utility?
- BillSyrattNov 03, 2019Initiate
Sorry for slow response. Some of my Powerlines are behind furniture and I cannot see the LEDs. If I have a slow system, I can check on the Powerline Utiility to see if one or another of the Powerlines has a problem or a particularly slow link speed, up or down.
Bill
