midnightfox
Sep 28, 2015Aspirant
Powerline XAV5001 Issues "Ethernet doesn’t have a valid IP configuration”
If anyone could help me it would be greatly appreciated. My powerline XAV5001 hasn't been working for quite some time now. I have a limited connection and when I try resolve it via Windows Net...
midnightfox
Sep 30, 2015Aspirant
Hi James,
When I would connect the unit directly to the router, I would loose connection all together from the internet on the other systems that were connected to the network through the powerlines.
It’s definitely a fault with this specific powerline.
Is it possible to downgrade the firmware manually?
In regards to how many Powerlines I have it was 4 originally.
Since I moved places I have left two of the working ones behind at my previous place.
I was experiencing exactly the same fault at my previous place with the faulty unit.
JamesGL
Oct 02, 2015NETGEAR Employee Retired
Hi midnightfox,
You might need to replace the defective unit as it might be a hardware issue.
JamesGL
Community Team
