Steve986's avatar
Steve986
Powerline XAV5001 not showing on the Netgear utility
Hi, I have 3 power line adaptors connected to my network via my windows 10 PC and talktalk router. All adaptors show 3 green LEDs and are supplying internet connection. My issue started when I updat...
  • Steve986's avatar
    Steve986
    Feb 15, 2016
    Hi,
    Success!! It wasn't the Ethernet cable. However the suggestion to try a wireless device seems to have done the trick. Initially when I used my windows XP laptop the utility showed the adaptors. When I reset the security the screen went blank with no adaptors showing. I thought I had blown it. However the next day after taking a brave pill I tried connecting the two adaptors separately to my normal PC just to check the security again and noticed that the security padlock was now in the open position. The main PC showed all adaptors connected on the network. I put them back in there normal positions and connected my devices including the fussy network player and hey presto it is back on line.
    Thank you for your help and patience.
    Steve986
