sp3cn4z
Sep 26, 2015Follower
Powerline XAV5601 Firmware request
Hello, I have 5 XAV5601 Powerline Adapters that don't work really good. Many times it happens that my connection brakes. So I looked with "Netgear Powerline Utility" and tried to Update the ...
JamesGL
Sep 29, 2015NETGEAR Employee Retired
Hi sp3cn4z,
Welcome to Community!
This type of powerline adapters are using the stock firmwares and no firmwares available in support site. The firmware loaded depens on the manufactured date that is why they do not have the same firmware version. There are some powerline model that has an option to update firwmare using the powerline utility.
JamesGL
Community Team
Patator100
Nov 30, 2015Aspirant
HEllo
I have the same issue as many of us : the adapter keeps doing a soft reboot every 10min
I have 2 of these adapters, same issue.
When I replace the adaptapers, on the same power socket (I've tried other socket also), with one of Devolo AV500+ or Netgear XAV5501, no issue at all.
Is there away to fix this issue ?
Thanks
- JamesGLDec 01, 2015NETGEAR Employee Retired
Hi Patatator100,
Please check my response on your other post.
https://community.netgear.com/t5/Powerline-Networking/XAVB5601-problems/m-p/1011992#M2735
