220Hotwheels
Feb 03, 2018Guide
Problem connecting two sets of powerline adapters to my network system
Hi I have a Netgear Nighthawk D7000 router and due to home layout need to extend the wifi network. I already have one pair of Powerline adapters (PL1000 and PLW1000 connected successfully but I now ...
michaelkenward
Feb 04, 2018Guru - Experienced User
OK. So you opted for the "two networks" approach. I'd expect that to work.
If that works, fine, but I would love to know if a single Powerline network can address two Powerline APs.
220Hotwheels
Feb 04, 2018Guide
Hi
I did try something similar using one Powerline adapter and two Netgear extenders (EX6400) but only one would work satisfactorily. With both connected I kept loosing wifi signal to all of the items connected to each which is why I went for the two Powerline adapter set up. Having said that I did not try the security button scenario with the EX6400, so that might work but as things stand at the moment I have spent enough time getting matters sorted so that I can sort out my new cameras so won't be fiddling any more anytime soon!!
Kind regards
Peter
