marcello1908
May 30, 2015Follower
problems with XWBN5201
HI, I'm very tired... I spent all night to combact with my lan....:( I bought a powerline kit with XWNB5001 for improve my wifi area. Unfortunatly I'd some problems... Actually the situatio...
michaelkenward
Jun 04, 2015Guru - Experienced User
I'm not sure that I understand your setup.
Is the XAV5201connected to the router/modem?
One recent visitor had the XWNB5001 there.
Is your pinging LAN or wifi?
Have you run the Netgear Powerline utility?
Does the Netgear Genie look right?
DNS stuff is usually down to the modem/router.
Which modem are you running off?
