tomdkat's avatar
tomdkat
Question about the Powerline 500 + WiFi XWNB5201 and wired/wireless connections
Hi!  I'm looking to replace a Netgear XAV2101 and XAVN2001 pair with the Powerline 500 XWNB5201 (and cooresponding Powerline adapter to connect to my router).   My question is:  will I be able to connect wired *and* wirless network devices through the XWNB5201 simultaneously?  In one particular room, I would like to connect a wireless printer AND a PC (via Ethernet) to the network, through the XWNB5201.  Will this be possible?
Thanks in advance for your help!
Peace...
Tom
    The answer to both questions is yes. You can use a plug's LAN and wifi at the same time.
  • michaelkenward's avatar
    michaelkenward
