mmaster1278
May 03, 2018Aspirant
Single Wifi Name | 3 Direct Connections | PLW1000v2 and AC1900 (C7000)
I have 3 goals. The goals are simple “Fast Home Wifi Everywhere,” under one Wifi name, and able to direct connect in three separate locations. Can it be done?:
1) I feel with both of the devices I ...
mmaster1278
May 06, 2018Aspirant
Wow. You were right. Simply changing the router and power line adapter to the same SSID did the trick. It’s now under one name. My only other question to you is how would I change the settings on the powerline adapter going forward? Now that it’s all under the same SSID, I cannot login into mywifiext.net. I’ve tried an Ethernet login and a wireless. How would I login to change channels, SSID/password in the future?
TheEther
May 06, 2018Guru
The Powerline adapter should have an IP address. You may have to look it up by logging into your router. Use that address to log into the adapter.
The other, less reliable option is to move near the adapter and then connect to the Wi-Fi network. Chances are that your device will connect through the adapter. Then mywifiext.net should work.
