PeteNVA
Aug 11, 2016Aspirant
Red Light Flashes - XBox not working
I have been using a several Netgear Powerline PL 1200 adapters on Verizon FIOS, and they worked fine (Plug n Play). Since switching to Cox on Monday, third light flashes red. My XBox gets 30 MB dow...
clithes
Aug 14, 2016Prodigy
Since you have changed ISP, and are now experiencing lost packets, I would check your MTU settings, as these could be different to your previous internet supplier.
http://www.tp-link.com/en/FAQ-190.html
Once you've found the correct setting, if it is different to before change the MTU value in your modem/router and see what effect that has.
Hope this helps
