brokerjoker
Jan 17, 2017Aspirant
Replacement PLW1010
I need to buy a replacement PLW1010. How can I do this?
- Jan 30, 2017
Thanks...
michaelkenward
Jan 18, 2017Guru - Experienced User
Where are you?
brokerjoker
Jan 18, 2017Aspirant
In San Diego...
- michaelkenwardJan 18, 2017Guru - Experienced User
I asked because Netgear seems to sell different packages in different regions.
Most Powerline devices come in pairs. (That's true of all makers.)
I haven't seen any wifi plugs sold singly.
Remember, you don't have to stick with Netgear. You can mix and match different makes and generations (speeds) as long as they use the AV standard.
- brokerjokerJan 18, 2017Aspirant
Michael,
I appreciate the response...unfortunately, all of which I am already aware of. I was hoping to get an actual NetGear representative to acknowledge if there was a possibility to order replacement components. As of right now (and as you stated in your response), I can buy another new kit and throw away the old... which is kind of like telling me that I should throw away my car and buy another one if the engine goes bad. That may be the only option, but definitely not the preferred one if the other components are still good (or in my case virtually new).
brokerjoker wrote:Michael,
You didn't say.
I will leave it to them to answer, I was just feeding back what I have learned here from watching the same question come up time and again. That no one from Netgear answered you suggested to me that they had not much to say.
This is not a sales channel. It is all about technical support. The Netgear people don't seem to have any more influence over sales than regular users.
I assume that you have already been down the sales route.
