charosa
Dec 06, 2016Follower
security setup
I have a PowerLine wifi 1000 essentials edition plw1010
I have my extender connected to my router which has a security password for the router. Now I am trying to add security to the extender and can't understand the directions provided in the box the extender came in. Can't I use the same password as my existing wireless network uses? I try to connect to the extender network and it asks for a security key. If I can't use my existing key what am I supposed to use?
Hi charosa,
Check this Installation guide.
- JamesGLNETGEAR Employee Retired
Hi charosa,
Hi charosa,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
