SJREUTER
Feb 05, 2018Aspirant
Self-Assigned IP address
I have 3 of these adapters, and seemingly out of nowhere, I can no longer use them to get internet access. I see "self assigned IP address" on my mac under the thunderbolt ethernet. I've had these ...
clithes
Feb 10, 2018Prodigy
I once had all my powerline adapters stop working at once, and tried everything you have to reset them. The way i fixed it was to turn off the circuit breakers at my fuse box that the powerlines were plugged in to. It seems there was some kind of interference in the electricity circuits that was stopping their functionality. Worth a try if you've exhausted all other options.
Hope this helps
Hope this helps
- SJREUTERFeb 11, 2018Aspirant
Thank you - I’ll give that a try!
